How can active TEMP & DTEMP in umat?
Hi to every body
I want to write a code of umat that in it I need to use temp and DTEMP.
now i want to know how can i activate these terms (TEMP & DTEMP)in cae file or in umat code .
i think they are inactive .
because when i wrote a umat code and added this instructino:(write(6,*),temp ,dtemp) then run with its abaqus cae file ,at the end ,when i checked the valu of them in temp file of
C drive .
i saw the valu of both of them were zero (0) but(while) i need and expect that they get valu .
now what is the suggest of you for solve this problem?
Regard
binam
C drive .
Regard
binam
