Renaming Dimension
Renaming Dimension
Renaming Dimension
Does anyone know how to change the name of a dimension in the model?
I want to change the dimension name for example from d145 to bolt_circle_diameter.
Thanks.
RE: Renaming Dimension
For Pro/E 2000i:
MODIFY->DIM COSMETICS->SYMBOL->pick your feture->select dimension->change name.
That's it!
Hora
In the text you have to exchange %D with %S and type the name whcich you wanted to.
I hope this is what oyu are asking for
