Liquid Level In The Wellbore
I have surface pressure, surface temperature and return time (surface to liquid level back to surface) from field testers. Data acquisition occurred from the time the well was shut-in through the pressure build-up. I have all the necessary information required to calculate the liquid level in meters (wellbore information, reservoir temperature, gas properties). I am looking for a better software that will allow me to calculate liquid level in meters for all sorts of conditions (deep, shallow oil / gas wells, CO2 flood resevoirs). I have one right now that works well for shallow gas wells (essentially uses Cullender and Smith correlations), but it is not sufficient for the various types of wells and reservoir conditions I work with. Acoustic velocity (m/s) is not linear in these pressure build-ups and need a software that will calculate this for each corresponding pressure and temperature data so that I can in turn calculate liquid level in meters. Hope this makes sense. It's a bit late and I've already worked all day. Thanks in advance.
RE: Liquid Level In The Wellbore
