Masonry buckling check for irregular section
I have a stone masonry pier that is very tall (on the order of 50' unbraced), but it's not a wall section. It more resembles an angle. I don't believe the standard equations out of ACI 530 are applicable to this section, specifically for a torsional buckling mode.
How would you go about doing a check on this? My first pass was to look at only the one leg to equate it to a wall, but the severe cracking suggests a torsional behavior, so I'm really at a loss on how to proceed.
RE: Masonry buckling check for irregular section
I didconsider that and will probably go down that route for my next check. I'm still concerned about the torsional aspect since the crack pattern definitely suggests that behavior.
csd-
that was the thought behind using just the wall as the initial buckling check, but the torsional component has me thinking that is only a good starting point.
