no penetration of the surfaces when using surface interaction
Hi All, I am using surface-to-surface interaction and I had defined "Hard", frictionless contact behaviour. It is supposed that "Hard" contact refers to an interaction without any softening, in other words, no penetration of the surfaces can occur. However when visualizing the results in the deformed mode I see penetration of the surfaces. How can I avoid this?? Is there something wrong in my analysis??
Rgds, Sergini
Rgds, Sergini
RE: no penetration of the surfaces when using surface interaction
Tata
It's a more expensive way of defining contact if you're bothered about some minor overclosure of nodes and would be better resolved if your meshing was better.
Tata
