Aluminum Angles in Bending/Flexure (Lateral Torsional Buckling)
I am trying to design an aluminum angle in bending/flexure.
The aluminum Association 2005 looks at:
1. Local buckling of leg tip in max compression (which I understand)
2. Leg in uniform compression (which I understand)
3. Yielding for flange in compression at various orientations. Not sure I quite understand this.
(There are no examples for angle in bending either?)
Mn = 1.3My
What is My defined as?
Is: My = Fcy*Sc? therefore, Mn = 1.3*(Fcy*Sc)?
or does My = Fcy*Sc need to be divided by ny = 1.65 or nu = 1.95?
Please advise.
Then they address lateral-torsional buckling and I do not quite understand what they are doing.
They say that:
When Me <= My, Then: Mn = (0.92-0.17*Me/My)Me
Me is later defined for different scenarios such as:
1. equal legs
2. lateral-torsional restraint at point of max bending moment or no lateral-torsional restraint
3. leg tip in tension or compression, etc.
My question is:
How is My defined?
Is My = Fyc*Sc?
As before does My need to be divided by nu or ny?
Mn = 1.3My
Please advise.
They say that:
1. equal legs
My question is:
How is My defined?
Is My = Fyc*Sc?
RE: Aluminum Angles in Bending/Flexure (Lateral Torsional Buckling)
There are 3 limit states
1) local leg buckling (which depends on how it is bent)
2) Yielding
3) lateral-torsional buckling
All 3 need to be checked
