Dished Ends On A Vessel
On a vessel, lets say 900mm ID, I am looking for the cheapest method of a end, a dished end or whatever is relevant, the flow characteristics should be good for water that never gets above 50°C.
RE: Dished Ends On A Vessel
-TJ Orlowski
The end caps might even be stock items at a large pipe supply outfit. In essence, they will be 2:1 SE heads, just fabricated to a piping standard.
It won't be very thick - if you assume a 3mm corrosion allowance you'll see a thickness on the order of 6 to 10 mm.
jt
