NX5 Part Attributes
NX5 Part Attributes
I have a part attribute that is residing in a part that is not needed any longer. It is however still in the attribute listing for a part that needs to be exported out of TCe for a customer. My TCe Object Export fails due to this bogus attribute and all efforts to remove this attribute have failed. I need verification of the proper way to remove this attribute from the attribute listing. Can anyone help?
RE: NX5 Part Attributes
File -> Properties -> Attributes
...that you can't delete the attribute?
If that's the case, try this. Go to...
Format -> Reference Sets...
...select the 'Model' Reference Set and then select the 'Properties' icon on the righthand side of dialog. Do you see the Attribute there that you're having problems with? If so, delete it there.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
John R. Baker, P.E.
Industry Sector
Cypress, CA
