SPECIAL GEAR PAIR
SPECIAL GEAR PAIR
SPECIAL GEAR PAIR
I have a Gear Unit from FALK (2120 Y2)and I have to manufacture a gear pair, but I don´t know what standard they use, I think they use transverse diametral pitch, but the pressure angle and the helix angle is not working.
FALK use special pressure, helix angle and diametral pitch for their gears; some one knows to tell me?
Thank you.
RE: SPECIAL GEAR PAIR
Measure the base pitch.
You can then work out the pitch and pressure angle.
If you are in the gear industry you really should know how to do this as it's one of the most used practises in the workshop.
Ron Volmershausen
Brunkerville Engineering
Newcastle Australia
http://www.aussieweb.com.au/email.aspx?id=1194181
