DPF nett effect on emissions?
Regeneration of DPF's seems to be quite popular and the system seems to be effective to control smoke. What is the nett effect on emissions and in particular Nox?
DPF nett effect on emissions?DPF nett effect on emissions?(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesThe world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
Engineering-centric businesses face a number of challenges today, but unmanageable design and change processes don’t need to be counted among them. Download Now
RE: DPF nett effect on emissions?
This can happen during normal driving at higher speeds without the engine controls having to do anything, in which case, no effect on NOx.
If an active regen is needed, the VW system does it by injecting extra fuel late in the power stroke (long after the peak NOx formation) which raises the temperature in the oxidizing catalyst (upstream of DPF in same enclosure) and that raises the temperature enough to light up the DPF. This shouldn't appreciably affect NOx.
In any case, the VW system has the oxidizing catalyst and the DPF upstream of the de-NOx catalyst, which takes care of any NOx that might be there. The North American version of that engine also has two EGR systems (a high-pressure system that has a quick response time, and a low-pressure system that responds slower but draws exhaust from after the DPF so it doesn't clog and draws it through a cooler to reduce temperatures even further).
All of these DPF-equipped systems are on engines that meet current NOx emission standards.
Main effect of these emission controls from what I can tell, is higher fuel consumption under some operating conditions (when active regenerations are needed).
The temperature inside the DPF catalyst itself is well below the NOx formation threshold, even during regeneration, if *that* is what you are asking.
Raising the exhaust temperature to initiate DPF regeneration is normally done by a combination of retarding injection timing (tends towards less NOx) and injecting fuel late in the power stroke which ends up being oxidized in the oxidizing catalyst, raising its temperature - but again, the oxidizing catalyst operates well below the NOx formation threshold, even during regeneration. The predominant effect is increased fuel consumption during this mode, not necessarily higher NOx emissions.
The VW system has several different regeneration modes, because each of the DPF, the de-NOx catalyst, and the de-H2S catalyst all require regeneration by different methods and different frequencies. The de-NOx catalyst is regenerated every few minutes by running the engine at stoichiometric (unusually rich for a diesel engine) which feeds the de-NOx catalyst a small amount of hydrocarbons to reduce the stored NOx. (This is done by temporarily increasing the EGR rate through the low pressure EGR system.) The DPF is regenerated every few hundred kilometers by raising the exhaust temperature in lean-burn mode. I don't recall how the de-H2S catalyst is regenerated, but it is at an even lower frequency.
http://www.dieselnet.com/tech/dpf_regen.html
thus now we have urea systems, so far, mileage is better but the head aches of another system to keep track of is yet to be seen
Only thing I can *maybe* see that could explain it, is that the VW system has the oxidizing catalyst and DPF extremely close-coupled to the engine and they are both in the same housing, so that the DPF is kept as hot as possible. The further the DPF is away from the engine, the more heat the engine will have to make in order to regenerate it.
- Steve
