ANSI 150# flange does not meet code?
Hey Everyone:
Kind of a odd question for you all. I know that if you use a flange from ANSI 16.5 that meets your temp and pressure reqs, you dont need to analyze the flange. I am noticing though that if I take a 16" 150# flange using a m=3 and y=10,000 gasket with a MAWP of 230 psi, I do not meet the thickness reqs of UG-34. Has anyone ever had a similair expierence or could explain to me why this is? Thanks!
Jason
Jason
RE: ANSI 150# flange does not meet code?
If you're applying a flange to VIII Div. 1, I'd hope you're using ASME B16.5, not ANSI 16.5.
This topic has been discussed here many times before. One example is thread292-261158: Sect VIII UG-34 vs. B16.5 blind thickness. A bit of searching will locate other threads.
jt
