drill chips
drill chips
I am looking for a reference of different types of chips produced by drilling with a cnc mill. specifically what kind of chips are desireable or indesireable and what one can change (speed/feed/coolant??) to go from an indesireable chip to a desireable chip.
Ive tried doing a quick google search but didn't find what i was looking for. wondering if anyone knows a good reference website or can give me a few pointers for a novice.
RE: drill chips
What material are you drilling?
What tool material are you using?
What diameter drill?
How deep is the hole?
Ben Loosli
RE: drill chips
RE: drill chips
RE: drill chips
What I would be even more concerned with is drill wear and built-up-edge. Drill wear diagnosis is covered in most "tech" sections of manufacturer catalogs. Try OSG Sossner, Mitsubishi and Guhring as a few examples.
As for starting points, use median values (SFM & in/rev) from the drill's manufacturer. If you don't know the manufacturer and are using a cobalt drill, start at 30 SFM and .004 in/rev and adjust from there.
The Manufacturing Reliquary
http://cmailco.wordpress.com/
RE: drill chips
RE: drill chips
The chips damage the workpiece.
The chips wrap around the tool or toolholder and interfere with the toolchanger.
The chips jam the chip conveyor.
The coolant is blocked from reaching the tool tip.
The tool tip is damaged by recutting of chips or rapiding into chips (CNC deep hole cycle).
In general, more drilling problems arise from underfeeding than from overfeeding.
Software For Metalworking
http://closetolerancesoftware.com
RE: drill chips
Start with an arbitrary feedrate, and double it until the drill splits. Then use half that rate.
Long stringy chips are fun to produce with a hand drill, but on a CNC machine they'll jam the drill in the hole and break it, and/or form a birdsnest that will snag a fixture, pull the drill to the side, and break it, and/or ... you get the picture.
Short chips literally fly out of the hole, and don't foul the flutes.
Mike Halloran
Pembroke Pines, FL, USA
