Antenna dBi issue.
Antenna dBi issue.
Antenna dBi issue.
Hi, it's my first time on the website.
I know how an isotropic antenna works. I work in the certification business and I keep seeing 0 dBi gain antennas. (Whip, Beamwidth 360 horizontal and 45 vertical.) Is this possible? I thought it was:
Beamwidth:
H, 360
V, 90
Gain = 3 dBi
Beamwidth:
H, 360
V, 360
Gain = 0 dBi
Please help, thanks.
RE: Antenna dBi issue.
Looks right,
for an omni antenna like a perfect dipole, the gain formula is 112/Beamwidth (-3 dB rolloff angle in degrees).
There are many simple formulas out there for gain based on the angle in degrees at the -3 dB rolloff in power (relative to peak).
dBi is decibels relative to isotropic.
bel = Alexander Graham Bell who first plotted in log base 10.
deci is 10xlogbase10(power), seems other scientists thought multiplying by 10 was easier to read.
Common alternate units for dB() are;
dBiC (C=circuilar polarization),
dBiL (L=linear polarization),
dBiD (D=dipole, which has 2.1 dBi gain, so if you have 5 dBiD gain, it's actually 5+2.1=7.1 dBi or dBiL gain).
dBi really needs something else added to it for completeness, either the word linear, circular(Right hand or left hand) or dBiD (which is always linear).
I'm guessing that those formulas actually calculate directivity, where
gain = (antenna efficiency) * (directivity)
For instance, if based on beamwidth, you expect an antenna to have 3 dBi of directivity, but the manufacturer advertises the gain to be 0 dBi, that would imply the antenna efficiency is 50%.
Peter
As Peter wrote, loss is the simplest explanation for the apparent anomaly in the 0 dBi gain and non-spherical coverage pattern beamwidth figures.
