Output problem with Com624P
I am using Com624P to calculate the deflection of a laterally loaded pile. The input and run parts seem to happen without any problem. But when I get to the graphic part I do not have any deflection curve available, only the p-y curves that I asked for during the input.
Also the ouput file looks weird; it contains input and output information but nothing on the applied load and the deflection (which appears in the examples for instance).
Has anyone any idea as to why the deflection curve is missing and how to get it?
Thanks.
Ben
Thanks.
Ben
RE: Output problem with Com624P
I think the two programs are originally developed by the same guy, Prof. Reese of the Univ of Texas.
