Sync. Generator's Rotor testing
Hi!.
do you know how to conduct Polarization De Polarization Analysis or test on sync. machine's rotor. The machine is rated for 3600 rpm, 60 Hz.
RE: Sync. Generator's Rotor testing
Bill
"Why not the best?"
Jimmy Carter
a hard but better way to check moisture ingress, its location, resin conditions, leakages with machine, lack of contact of coil with core, etc
I hope that this helps.
http://www
Bill
"Why not the best?"
Jimmy Carter
