How to program PLC for least Squares
Can someone help me determine how to program a least squares routine for determining the slope and intercept for a number of xy coordinates?  I am using an AB Micrologix 1100. Thanks.
RE: How to program PLC for least Squares
This is sort of a dirty solution but you place your x data in the array starting at f9:0 and the corrosponding y data in F10:0.  Then you place the number of data points in N7:1.  Call the routine and it returns A in f11:12 and B in F11:16.  Use the equation y = A + Bx for your curve fitting.
I have uploaded a file but have not tested it but you should see how it works if I made a mistake.
Lanny
