Snapshot on NX-IDEAS 5
Does anybody know if the option to make a snapshot of 3D model, this feature was available on UNIX type workstations, is it available for windows?
RE: Snapshot on NX-IDEAS 5
Are you looking to export a .jt file?  This type of file is a lightweight 3D version of your model that requires the seperate JT viewer - JT2GO.  You can pan, rotate, zoom and turn components on and off.
Type HC then hit enter. Creates a JPG or BMP not sure in your user directory
