Pronest 8 cutting "class"
In Pronest 8, when you add a part, you choose "Material" and "Class".
I've input the material in the material database.  Where do I input the class ie. Oxygen, Nitrogen, Air.  I have a spreadsheet that calls out classes, that also selects power and feed settings.  Under "class" in the parts list I see options for Oxygen, Nit, Air, but when I select one, I get the error:
"Error updating part: Flat-Pattern2-D31_stack_x1.dxf = The value for [Class] is incorrect."
Any idea what to try next?
