Difficulty with dimensioning to virtual sharps.
Howdy all,
So I have a dimension that is reading wrong because I can't pick up the virtual sharp.  The probelm is the angle on the inside of the radius is very obtuse, close to 175°.  If I change the dimension to 135° I can pick up the sharp and then change it back with no problem to get the correct dimension, but this solution will not work for a real drawing, because changing that dimension would break everything.  Is there a way to pick up the virtual sharp on a very obtuse angle?  I have included a couple of files to suggest the problem.
http://files.engineering.com/getfile.aspx?folder=67d40a94-fa54-44ee-b329-e9bab888c5c2&file=virtual_sharp_test.SLDDRW
I also fond the key to creating the virtual sharps from this post:
thread559-123394: Difficulty dimensioning edge of hole
Thanks for your help.
-Kirby
Kirby Wilkerson
Remember, first define the problem, then solve it.
RE: Difficulty with dimensioning to virtual sharps.
Ctrl-click both lines, and then select point from the sketch toolbar.  It will create an actual point at the vertex of the intersection, which you can then dimension to.
HTH...
That's what I did as instructed in the thread I referenced, but that does not create a point.  It creates a couple of reference lines.
O.k. hunting around and clicking randomly I found the point that it inserts. The problem is that the point is not displayed.  At least not when I have Witness selected on Tools --> Options --> Document Properties --> Virtal Sharps.  Changing this option to Plus or Star make it visible so I can select it.
Thanks for your help and sorry for doubting you.
-Kirby
Kirby Wilkerson
The reference lines point to the point.  Just click at their virtual intersection and you'll have access to the virtual point.  You can also change your virtual point symbol to an asterisk or other shape in the Tools>Options>Document Properties>Virtual Sharps location.
Matt Lorono
Lorono's SolidWorks Resources & SolidWorks Legion
If the display style of your virtual sharp does not show a visible point, there should still be an imaginary one there that you can select.  You may need to use the "selection filter" when you're trying to dimension to it.
Joe
SW Office 2008 SP5.0
P4 3.0Ghz 3GB
ATI FireGL X1
