help NX6 no longer perform the join operation
Good morning
Someone of you could help me.
Since last week my ugs NX6 no longer perform the joining operation. Although listed in the part navigator in the model still appear disjointed parts.
As if I did and when I want to or subtract some hole lake I have to do so because although the individual parts together does not recognize it as one,
I hope I can help and sent a picture of how the model appears after you have joined
Greetings you soon
Greetings you soon
RE: help NX6 no longer perform the join operation
Perhaps if you took a different attempt at explaining it or if you included some images or even part files it might help.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
or completely deselecting them and then reselecting them
But after doing the operation
Still appear the lines dividing
Both bodies as if they were individual
Insert -> Trim -> Join Face...
...and with the 'Join Method' set to 'On Same Surface', select the body and hit OK. Now if a message comes up stating that it 'Failed to change topology' that means that the 'extra edges' cannot be removed and the model is what it is.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Use any one of the faces as the "face to replace" and the other face as the "replacement face"
At the end of the day I seldom if ever take the view that the geometry is what it is. I take the view that my job as a modeller is to bend the geometry to my will so I make it my business to come up with ways to make that happen. It is whatever I want it to be.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
