Batch Process and Custom Macro
I am looking for a macro that will allow me to select a directory, then run a given macro on all the files in that directory.
Found this post ... http://www.eng-tips.com/viewthread.cfm?qid=209635
But I am not sure what the macro is actually doing.  I ran it and didn't see where it did anything to my files.
Can I adapt the modules to accomplish my goal?  Where is the code that is actually doing something?
Is there a better way to batch a macro across an entire directory?
RE: Batch Process and Custom Macro
By the way - I know that SolidWorks task scheduler can help out, but there are limitations and I can't use it.
Well, I can certainly take a look at your macro, but I do not want to create an new assembly or reassign colors.
I want a routine that will allow me to select a directory, then run a designated macro on that directory.
I want to batch all drawings to a PDF: I run the batch macro, designate the directory, maybe designate the macro I choose to run.
Then I want to convert all drawings to DWG. I run the batch macro, designate the directory, maybe designate the macro I choose to run.
Next I want to run a special custom macro. I run the batch macro, designate the directory, maybe designate the macro I choose to run.
macro, smackro, why not just use PAC4SWX ?
Hardie "Crashj" Johnson
SW 2010 SP 2.1
HP Pavillion Elite HPE
