Effective thermal conductivity of composite pipe
I am using a specialized well bore anlysis program that calculates thermal profiles in down hole. The program requires a "k" thermal conductivity value for drill pipe as an input.
I am using a pipe that has insulation at different locations along its length. I would like to know how to calculate the effective "k" (thermal conductivity) of one pipe section "L". The pipe is basically steel with an insulation layer.
RE: Effective thermal conductivity of composite pipe
Tata
Do you mean that the insulation around the steel pipe is different or non-existent at various positions and, if so, what are they? It is very problematical to develop a socalled equivalent K . Mpre realistically you might need a piecewise solution using a different program for this.
I would strongly suggest that you explain exactly what you are trying to do and give us a sense of thermal boundaries and flow conditions, if any.
