Effective Thermal Conductivity of Pipe
I am using a specialized well bore anlysis program that calculates thermal profiles in down hole. The program requires a "k" thermal conductivity value for drill pipe as an input.
I am using a pipe that has insulation at different locations along its length. I would like to know how to calculate the effective "k" (thermal conductivity) of one pipe section "L". The pipe is basically steel with an insulation layer.
RE: Effective Thermal Conductivity of Pipe
-Kirby
Kirby Wilkerson
Remember, first define the problem, then solve it.
