AutoCAD Electrical
AutoCAD Electrical
We're about to start a major project replacing our LV switchgear. Our existing drawings are virtually all hand-drawn from the early 1970s, and we're going to be redrawing the whole lot, an estimated around 6000 - 7000 drawings between us and the vendors. AutoCAD Electrical looks tempting based on the promotional blurb, and if we achieve a fraction of Autodesk's claimed time-savings then it will likely pay for itself fairly quickly. The demonstrations we've seen look quite impressive, but they're obviously part of a sales pitch and when talking to salesmen I'm a skeptic at best and a cynic the rest of the time.
Does anyone have any positive or negative views on AutoCAD Electrical? We're competent enough CAD users, but before we spend a 5-digit sum on software licenses I'd appreciate some views from existing users. How easy did you find the migration from standard AutoCAD to Electrical, and what problems / limitations have you had with the automation?
RE: AutoCAD Electrical
The controls is built on a full version of AutoCAD, so there wasn't a long ramp-up time for me when I learned to use it. I can still produce power one-lines and other types of power diagrams using the base AutoCAD methods I was used to using, but those types of drawings don't seem to be able to take advantage of the automated tools the same way as electrical controls diagrams can.
xnuke
"Live and act within the limit of your knowledge and keep expanding it to the limit of your life." Ayn Rand, Atlas Shrugged.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
Also the project manager aspect is very valuable. It will allow the user to keep the individual drawings organized and sorted. It also has a project wide plot function which is much nicer than the AutoCAD batch plot utility.
If most of the drawings are 3D layout drawings, then you are most likely out of luck. However you might check the supplied libraries of ACE for you existing equipment. It does have an extensive lineup of american switches, pilot lights contactors etc. This is valuable in of its self.
There will be some PLC or DCS I/O, motor starter schematics, interconnects, termination details, etc, etc. We expect to have a handful of fairly standard starter schematics so I think I can imagine using some of the automation to populate the starter shcmatic with drive-specific details. The ability to link through from the PLC I/O drawing right through to the motor starter has a certain appeal. Or maybe I'm listening to the marketing guys too much? It's no good if the automation costs us more time that a plain drawing!
It sounds like it would be helpful based on the types of drawings you mentioned, especially if you have standard drawings. I did a bunch of standard drawings for a project using the Excel import/export utility, and it worked great. I simply filled out a spreadsheet for each drawing I needed to make, and the software created the drawing for me. It was easy to create a bunch of spreadsheet files and not have to worry about the drawing. They all looked nice and uniform, too.
Before committing to buying, you can try it out for 30 days for free, with full functionality. I'd recommend you check out the demonstration version.
xnuke
I'll have to give them a little nudge about the 30 day trial. That sounds very useful. Quite where I'm gonna find 30 days free to play with the software I simply can't imagine: a 30 minute trial would probably exceed my spare time right now. Still, can't complain - better busy than quiet!
