NATURAL GAS PIPE LINES.........PITTED AREA SAFTY
WHAT ARE THE MEASURES AND WAYS TO MAKE PITTED AREA/SPOTS ON PIPES TO MAKE IT SAFE TO AVOID LEAKS AND OTHER HAZORDS,AND HOW PITTING ACCURES WHILE PIPES ARE LYING OUTSIDE THE GROUND(EARTH),AND HOW IT STARTS IN THE GROUND.
RE: NATURAL GAS PIPE LINES.........PITTED AREA SAFTY
Wet storage, differential oxygen conditions, and carbon steel will pit unless something is done to prevent it--like coating, etc.
Don't allow pipes to sit on ground. As a minimum, put thick layer of gravel (for drainage) under them.
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
As far as how the corrosion accures, or occurs, the iron in the pipe (Fe) is reacting with oxygen in water to produce iron oxides/hydroxides, but this is a very simple explanation, you can easily look this up in any corrosion book and background info. I highly recommend you seek outside help from consulting company in the area of NDT to map corrosion& pipeline integrity to complete fitness for service and repair options to assist.
