Making silicone bladder for composite molding
I've seen several good posts on composite bladder molding, but I'm wondering if anyone has some specific recommendations for:
1) Silicone materials, sources, methods to use to make the bladders
2) Wall thickness of the bladder
FYI we can't used a trapped solid rubber mandrel since it would be trapped in the mold due to the bends in the part.
RE: Making silicone bladder for composite molding
www.compositescentral.net
I suppose was post was a little vague, but I was just wondering if there are rules of thumb for building bladders. We'll experiment with some silicone molds.
Try the silicone from Smooth-On. They are at www.smooth-on.com. I have used the silicone that they specify for moulding as well as their dragon skins 10 minute. The ten minute is colorless and quite elastic but does run a little bit. The material for mould making is green and more stiff. Either of these can be sprayed or brushed as well as injected into a mould using an epoxy gun to make a tube. I have used with epoxy and polyester, vinyl ester and they work fine.
Good Luck
Mike
