MathCad Drop down menus
Can anyone offer how to advice on creating drop down menus MathCad? I use MathCad versions 6, 13, 14, 15 and 2001i.
Thanks in advance for any assistance.
RE: MathCad Drop down menus
I think what may work is the list boxes. Go to Insert > Control > List Box and see if that works for you. I acually found your post today while looking for the solution myself so I have not played around with it too much yet.
This doesn't appear to be a true drop down menu but is the closest thing I've found yet, hopefully with some tweaking both of us can get it to suit our needs.
In my search I also came across this that you may find useful.
http://ww
At the bottom of the page you can download the files used... hopefully I'll be able to reverse engineer them to do what I want.
This is off-topic, but whenever I want to read a table such as the AISC database, I simply import it from a spreadsheet into a data table right in my Mathcad worksheet. Then use vlookup functions to get data out of that. I do not want to have to manage a bunch of other spreadsheet files along with my Mathcad worksheet file.
chichuck
