Matrix/Array Help
Matrix/Array Help
Matrix/Array Help
I had a wonderfully working worksheet before I went home for the night.  When I came back in the morning, it suddenly decided that it had errors.
The worksheet imports data into a table that has two columns, and was working great, but now the command current:=data <ctrl><6>1 has an error that says "This value must be scalar or a matrix".  Why would the column operator suddenly stop working?  I literally changed NOTHING. It does this now on all worksheets whenever I import data, or even just create an array by hand.  Oddly, the column operator works just fine for the other column of data.
Any thoughts on what happened and how I can fix it?  I am unable to post the worksheet.
RE: Matrix/Array Help
Why don't you attach your worksheet? Anything below 14 would be fine.
