Wierd meshing problem
Hello All,
I have a two piece assembly consisting of a tube with a flange welded onto it. The flange was placed first,with the tube mated to it. When I meshed, only the flange would mesh and no elements were created for the tube. When I opened up the tube by itself, it meshed without any problem. I then created a similar assembly, but placed the tube first, then mated the flange to it. Now the tube meshes and the flange does not!
I've made certain that materials were assigned to both pieces and that the part accuracies were the same. If anyone has any ideas on what the heck could be going on I would greatly appreciate it.
Marcus
Marcus
RE: Wierd meshing problem
Steve
Stephen Seymour, PE
Seymour Engineering & Consulting Group
www.seymourecg.com
Marcus
