Batch "step in" using template file NX 7.5...
I'de like to be able to do this based on my custom Model Template file.
The primary goal is to automatically get my Parts list referenced attributes.
Secondary to have the same look and feel as all my work.
Possible?
TIA
Dave
RE: Batch "step in" using template file NX 7.5...
I think for what you need there's a system supplied base part file for STEP imports in metric and inches in the appropriate directory. One simple way to achieve your desired outcome (after backing up the original) is to replace it with your own.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
Yeah, thats the only answer I could find and it works just fine.
Thanks!
