Need a Simple Pass Sticker Dispenser
Is there label sticker dispenser that will spit out a green pass sticker when and only when the tester deems a pass.
So basically I want my tester tied to this label machine and dispense a pass sticker when tester determines that module passed the test.
Any ideas would be helpful.
RE: Need a Simple Pass Sticker Dispenser
Perts,
A very general question, that needs more specifics.  What kind of controller do you have running your tester?  Is it a PLC, is it an embedded micro solution?  What capabilities does your label machine have?  What is the make and manufacturer of the label machine?  Is the tester a custom built piece of machinery or is it an off the shelf piece of equipment?  Make and model on the tester if it's an off the shelf item.  These questions will help others give you better advice.
Rich......viking2
Richard Nornhold, PE
http://www.personna.com
Yes,
We design and manufacture label dispensers that do what you want.
Shoot me an email.
Charlie
www.facsco.com
