MS V8 level display window will not retain layout
Every time I open the level display window I have to reset the way my levels are sorted. It use to be that once I set the display order, column size, and etc. MS would remember these settings. Now every time that I open the level display window MS resets the display to sorting by level "number" and I want it to sort by the "used" column. How do I change this to remember my settings?
RE: MS V8 level display window will not retain layout
By default the UPF file for V8i SS1 release is stored here.
C:\Documents and Settings\<Windows User Name>\Local Settings\Application Data\Bentley\MicroStation\8.11\<Ridiculous Folder Name>\prefs
Depending on your version it might be located in a different location. Let me know what version you are running and I can let you know where to find it. Also your CAD System Administrator may have moved it to a network drive.
You could go to the MicroStation pull down menu and select Workspace > About Workspace and see the current UPF file used.
HTH,
Bob Mecham
Training | Consulting | Programming
www.EnvisionCAD.com
Facebook: http://www.facebook.com/EnvisionCAD
Twitter: http://twitter.com/envisioncad
Your default location for V8 2004 edition UPF is located here C:\Program Files\Bentley\Home\prefs
Do you have a custom workspace at your office?
Did you copy your V8 2004 UPF file and make it for V8i?
Are you sharing a UPF between V8 2004 Edition and V8i?
If you are not in a custom workspace and running on the local drive my guess is that you are locked out of the new folder location Document and Settings. Check with IT and see what they say.
HTH,
Bob Mecham
www.EnvisionCAD.com
Thanks!
