2deditor compatibility with a 64 bit machine
It appears as though the 2d editor program is only for a 32 bit machine. I was recently upgraded to a 64 bit machine and need the ability to edit and at times, create, dwg files.
Does solidworks have a program similar to the 2d editor that is compatible with a 64 bit machine?
RE: 2deditor compatibility with a 64 bit machine
I haven't had any problems with the 2D editor running on my 64 bit machine in the past, however I haven't used it since upgrading to 2010.  What sort of problems are you having?
Works on my x64 bit machines.
Anna Wood
Core i7 EE965, FirePro V8700, 12 Gb RAM, OCZ Vertex 120 Gb SSD, Dell 3008WFP 30" Monitor
SW2010 SP2.1, Windows 7 x64
http://www.solidmuse.com
http://www.phxswug.com
