Exhaust gas blower housing dismantling
Hi
I have an EGB in front of me, and I would like to open it, because there is a small component which has melted inside of it.
The EGB looks like this (see link):
ht tp://www.f ime-motors .it/prod.a spx?p=5004 8&h=h2
In the picture, on the curved side, one can see that there is some kind of bolt (it looks rough and fragile in reality) with something black (it's a spring) under it. It is this bolt that stops me from opening the case, because I don't know its function.
So my question is: what is this bolt with the spring under it for? If I open the housing, will I be able to close it again as before without too much trouble?
ht
RE: Exhaust gas blower housing dismantling
Valuable advice from a professor many years ago: First, design for graceful failure. Everything we build will eventually fail, so we must strive to avoid injuries or secondary damage when that failure occurs. Only then can practicality and economics be properly considered.
