Which tool steel is the best for welding?
I am designing an assembly fixture that will require a welded tool steel sub assembly. What is the best tool steel for welding? Anything that is heat treatable to 60-65 RC will suffice for my application. Thanks.
RE: Which tool steel is the best for welding?
Thomas J. Walz
Carbide Processors, Inc.
www.carbideprocessors.com
Good engineering starts with a Grainger Catalog.
And my own comments:1--are you sure you still want to do this? 2--Find a welder experienced in this kind of welding and one that has the proper facilities for pre heat and post heat.
