Where is the Routing Template?
I am begining to implement routing here but I can not seem to locate the routing template.  The help file states that it is created the first time you create an assembly with the routing add-in activated but it does not seem to be happening.  Suggestions very welcome.
BB
RE: Where is the Routing Template?
I just tried it and the template went to my default assembly template location. Did you search your local drive, including hidden folders? I've noticed that SolidWorks will dump stuff into hidden folders.
Jeff Mirisola, CSWP
Design Manager/Senior Designer
M9 Defense
My Blog
Thank for all the suggestions even though they did not resolve the issue.  I ended calling the VAR and they had to go into the reg and copy, delete, paste, etc. during a webex.  Honestly once I gave control of my screen I could not keep up with him but he did get it resolved.
BB
I was going to suggest copy, delete, paste, paste, delete, copy, delete but then I started to think I had one of the deletes out of place and you don't want to delete at the wrong time. Glad to hear your VAR got it right.
Jeff Mirisola, CSWP
M9 Defense
My Blog
Nice thumbsup2
