astm e119 - mtl stud track attach directly to steel beams/columns SFRM
are there typical approved assemblies in UL, gypsum association or warnock hersey which INSTEAD of using the Z-clip to connect a stud wall allow the metal stud track to be directly attached to the steel beam/column AND than "embed" the stud track in the spray fireproofing being applied to the steel beam or column?
can't seem to find anything unless it uses the Z-clip.
steve yarnall
http://svyarchitect.blogspot.com/
