I-DEAS - how to check or change the surface tolerance ?
Hello all,
I read in several model files from other Engineering Program. But I find that it is difficult to rebuild or fix the model file, because there are too many error surface in this model file.
Can anyone suggest a good way to check or change the surface tolerance that i guess the main reason is?
RE: I-DEAS - how to check or change the surface tolerance ?
Or change the import tolerance in I-Deas to match your tolerance in your program you are exporting from.
Also try to import the file by type this in
/xto co bo fc im
THis is the old IGES import.
Try exporting out a Parasolid and or step. Those translate better.
Make sure you have stitch turned on when you import.
Today, I find a good way to do...
Firstly, I clear the bad file by /xto co bo fc dc, and extract a new surface data to export.
Then read in again, and change the tolerance of the bad file to .01mm by /mo spe t mo.
So I can easily to finish my work now.
Thanks for your suggestion.
