Corrosion rate of carbon steel in seawater
Can anyone give estimate figures for corrosion rate of unprotected carbon steel in seawater as a factor of depth and temperature? Are there any technical literature/study reports which is useful?
RE: Corrosion rate of carbon steel in seawater
Effect Of Immersion Depth On Marine Corrosion Of Mild Steel
Vol 61, (9), 2005, pp 895-906
there are other for temperature, water velocity, nutrient content and many more parameters
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
http:
http://w
it contains a lot of info on sea water corrosion and on the effect of th emain factors like salt content, oxygen content..
hope this help
S
Corrosion & Rust Prevention Control
