DN or NB
DN or NB
DN or NB
Good day all,
I'm having some contention over the use of DN or NB, now my understanding is that for metric units you state: DN 600 mm
or imperial units: 24" NB
Now due to possible ignorance NB has been used for both situations i.e. 600 mm NB or 24" NB
I cannot find anywhere that states explicitly what is correct i.e. code statement or dictionary. I feel that I may lose this battle due to the volume of rework but I'd at least like to know that I'm not being an expletive.
RE: DN or NB
"When in doubt spell it out."
I have no idea what either DN or NB might possibly mean in the limited context of your post.
RE: DN or NB
My bad,
Diamètre Nominal or Nominal Bore for Pipe/Nozzle sizes
RE: DN or NB
The NPS (Nominal pipe size) is the standard used in North America to define a pipe size (inches). Nominal Bore (NB) is used interchangeably with NPS. The European standard equivalent to NPS is DN (diamètre nominal) and sizes are measured in millimetres.
RE: DN or NB
Yep this is all understood, so how do you tell someone that you can't use NB with a metric unit? ASME code reference for example.
I agree this is common knowledge and it 'just is right' but how do you argue the point more effectively?
RE: DN or NB
It depends under which code you are designing. European standards make use of DN designation (take a look at ISO 6708). American standards use NPS designation.
RE: DN or NB
Agreed, this is where the complication lies. Some projects are ASME codes but with metric pipe/nozzle sizes.
RE: DN or NB
IMO it is a false problem. Nominal Bore or better NPS is always expressed inches (imperial unit) and DN is always expressed in mm.
