A question on NX7.5
A question on NX7.5
A question on NX7.5
Hi Guys
I'm using NX7.5.0.32 on a Windows7 64bit, and I have a question hopefully someone can answer for me.
I use the curve length command quite extensively, and it has changed between NX7 and NX7.5 in that it no longer is a dynamic input. What I mean is that when I select a curve in the 'curve length command' it automatically reverts to the last curve limit. Is there a way to change it so that it picks up the curve length of the selected curve?
Hope this makes sense.
Best regards
Martin
Senior product designer
Steinhobel Designs
RE: A question on NX7.5
I'm not sure which command that you're talking about.  Are you talking about...
Analysis -> Measure Distance -> Length
...or are you talking about...
Analysis -> Measure Length...?
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Hi John
The command is under - Edit->Curve->Length.
Sorry for not making it clear.
I see what you mean and I agree that this appears to be a mistake.  I'm opening a PR and will get back to you with what I learn.
John R. Baker, P.E.
Industry Sector
Cypress, CA
What I do is type zero in the total box and hit enter. Then I pick the curve I want and it will display it's full length.
Ron Dawson
Manufacturing Engineer
Ducommun AeroStructures-Parsons
http://www.ducommunaero.com/index.html
Giddy up... its been bugging the @#$% out of me!
Thanks John
I just added my approval to the fix this morning.  Hopefully it will make NX 7.5.2.x.
John R. Baker, P.E.
Industry Sector
Cypress, CA
