Industrial twin screw extruders sizes
Hi All,
am working on conceptual design for new plant, i need general information regarding the industrial extrouders layout and sizes Vs. throughputs ~300kg/hr.
is there is a table the give technical parameters regarding the extruders sizes.
AW.
RE: Industrial twin screw extruders sizes
I haven't seen any tabulated values of any twin extruders  o
You can get almost any size you want.  A guest manufacturer at our site uses Werner Pfleiderer Extrude rs, all with 120mm bore.  The also have 2 smaller WP Extrude rs, size unknown.   The size is going to be determined by your product and require products rates.
You need to get your requirements lined up and call the different manufacturers.
http://www.coperion.com/Default-L1-2-26-55-125-155.aspx
