How to turn off wire harness centerline display in 2D drawing view
Does anyone know how to turn off the centerline display when you place a assembly view containing wire harness?
Thanks for your help
RE: How to turn off wire harness centerline display in 2D drawing view
I wrote a VB6 program that will iterate through each view on the Active Sheet and hide all centerlines. I can send you this program if you would like.
