Create part from xyz data
I have xyz co-ordinates for the outer surface of a part I wish to create in ABAQUS. The part will resemble a cylinder with variable centreline. (If the cylinder runs longitudinally down the z-axis, I have (x, y) points for the outer surface of the cylinder for different values of z.)
Is it possible to somehow import these co-ordinates into ABAQUS and create the part.
Matt
Matt
RE: Create part from xyz data
