cheap plastic moulding methods
What is the cheapest moulding method for a plastic object with approximate dimensions 34" X 34" X 3" ?
RE: cheap plastic moulding methods
What shape is it?  How many are you making?  What properties must the molded object have (i.e. what material)...
Vacuum forming springs to mind but may be unsuitable for several reasons depending on your real requirements.
Posting guidelines FAQ731-376: Eng-Tips.com Forum Policies http://eng-tips.com/market.cfm? (probably not aimed specifically at you)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
