How do I bridge a gap?
I'm trying to connect 2 cylindrical objects, but one is also helical (a spring) so I'm not sure how to make a guide path that's perpendicular to both ends.
But the "Bridge" doesn't have to be perfectly tangent. I'm just throwing together concepts for a rainstorming session, so if you have a quick & dirty way to sort of fake it, that's okay.
RE: How do I bridge a gap?
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
John - I don't know anything about mesh surfaces. I tried experimenting with the command & reading the help file but I'm totally lost. I probably need more advanced training, but 99% of what we do here is simple Extrudes, Revolves, etc.
Hudson - it appears your sample .PRT is from a newer version of NX. We run NX4.
I "faked" it with a simple extrude to bridge the gap. It doesn't line up perfectly on the coil side, but you can't tell unless you zoom way in. My manager is happy so I'm just going to move on.
Attached is a simple example.
John R. Baker, P.E.
Industry Sector
Cypress, CA
I finished by uniting the various bits.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Is there a reverse button in the Through Curves dialog box in NX4? I can't find it.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Best regards,
Michäël.
NX4.0.4.2 MP10 / TCE 9.1.3.8_build_0711 / NX6.0.5.3 + TC8.1 Unified / NX7.0.0.9
Belgium
