Assigning density at assembly level
I have a large assembly in which many components don't have a material assigned to them. I would like to override to part level material densities and assign a density to the assembly level. Is this possible and if so, how do I do it?
This techniques would be close enough as most of the components are the same material.
RE: Assigning density at assembly level
http://
Not sure if it will help.
With SW2010 you can assign material to all parts at the same time.
You might be interested to try this macro too http://ww
A really good tool to use :)
Deepak Gupta
SW 2009 SP4.1 & 2007 SP5.0
MathCAD 14.0
Boxer's Blog
You can assign mass properties to both parts and their assemblies. But it is not a good practice.
Best regards,
Alex
