Easy way to find Pier Pad Capacity
Hi all, I have a pier that has been modified. A square concrete cap was added to the top of the pier to take additional moment. The pier is 6' in dia. The concrete cap size is 20' square. What is the easiest way to find out the moment taken by the concrete cap? I know the lengthy procedure from books. I need a very quick check or calc. Thank you.
RE: Easy way to find Pier Pad Capacity
Of course, a sketch would clarify the problem.
