How do you back up Intralink 9.0 data to offline directory?
I need to move all files from an Intralink Product folder to an offline directory where the project will be worked on outside of Intralink. I know how to do this on a file-by-file basis: if I have a file open in Pro/E, I can switch to offline mode, set the target folder as the working directory, and select "File/Backup" from the Pro/E menu which backs up the file (and dependent files) properly.
So that works, but this Product folder has a ton of files and it would be nice to be able to back them all up to the offline directory without opening each one separately into session to do it. For example, on the Intralink folder view I can select all files in the folder but there doesn't appear to be an option to back them up offline.
Keep in mind when answering that I am not an IT-savvy person, but I can get such folks involved if necessary. This just seems like a basic function that should be easy and obvious, but maybe not.
Thanks!
Thanks!
RE: How do you back up Intralink 9.0 data to offline directory?
Dave
I just want to select all the files in the workspace, push a button, and then have all of the discrete Pro/E files from that workspace appear in a directory that is unrelated to Intralink.
