Losses of appearance on conversion to Iges or Step?
I am about to work on some SW files older than version 2010. Once I save the modified file in SW2010, and in case I need to send the modified files back, I will have to use either Step or Iges format because the original files are made in an older version. Since I will most likely only work on appearances and create renderings and animations and not changing the "essence" of the files, can I expect that the modified appearances will be preserved in the exported files? So, can I expect the SW older than version 2010 to recognize the appearance differences made in SW2010 and exported to an intermediate format?
RE: Losses of appearance on conversion to Iges or Step?
While STEP214 and IGES retain colours, Parasolid is usually the better format to use.
http:/
While they will retain colours, it may not retain Appearances because they have changed drastically over the last few versions.
- - -Updraft
Michael
